E-sav
02.13.2009, 04:54 AM
I'm not sure how the Axial lockers work, the Epics only have one beadlock ring per wheel which puts equal pressure on both sides. They fix with six bolts. I can tell you that the Epic rings are 6cm in diameter and the bolts on opposite sides of the wheel are just about 5cm apart if that helps.
The Epic wheels have the correct offset for the Slash though, that's why I went for them.
