02.13.2009, 10:36 AM
I am not so sure this is actually true. I am testing with a 7xl motor - which will draw as much or more current as a similar Kv Neu or Medusa. It is well heat sinked and seemingly conservatively rated - I suspect it will do everything the Mamba max esc did without the need to add a fan or external BEC (so about 1/2 the price). The downfall is the size - it is a behemoth!
Good to know. It does seem a bit larger, but that should only pose issues if you plan to run it in a buugy. Most mts and truggies have enough room. I do wonder if it will hadle the load of heavier tires and tall gearing, as i always felt the MM was a bit marginal at that, in the southern summer that is...
If it can handle a 7xl, that is pretty good. That motor is an amp hog, especially after it warms up.
