MM and BEC help needed
johndeerekid
Question MM and BEC help needed - 02.13.2009, 01:37 PM
hello everyone i am going to be running BL in my e-maxx soon, and i need some help with setting up my esc. i will be running 2 7 cell 4700 batts, a bidproduct 1845kv hacker knock off, 68/22 gearing, and a CC BEC.
can you guys tell me what i should set these at-
brake/reverse type:
brake amount:
reverse throttle:
punch control:
drag brake:
start power:
motor timing:
motor type:
arming time:
cutoff voltage:
throttle dead band:
also should i run my batteries in a paralell or a series?
and i recently bought a CC link kit and BEC and when i hook it in it says pheonix link, but it doesnt work with the castle link software i use for my MM, does the BEC use a different program?
thanks so much!! -Wes
