What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.15.2009, 04:09 AM
Linc- I like it. I would lean toward the Sentra, also. Check out evparts.com. A 30kW motor/controller setup will run about $3000. You might have to upgrade to make 60mph. On batteries- Pb will be cheap, Li will be expensive. I would start with the Pb type. If it works well then sell them and put the money toward the Li batteries.
...they [Tesla] are using lithium ion technology for battery storage and seem to have pretty much perfected the method with one of the longest range parameters. I believe it is something like 100 miles or more.
It's (conservatively) 200 miles per charge with the Roadster. I would think the sedan will have better mileage, if it isn't being made as powerful.
