ssspconcepts
ssspconcepts's Avatar
02.15.2009, 11:22 AM
Originally Posted by Steve182 View Post
I just looked up the Kyosho spurs the Mike has in the store, they look good and heck they are cheap!
It says you cannot used hardened pinions with them though. Arent all the 5mm mod 1 pinions hardened?
I don't recall it saying that in the past. I have had several conversions with the kyosho spurs and haven't had any problems. Obviously the steel spurs are optimal but plastic should be fine if your gear mesh is correct and you use appropriate diff fluid.
