02.15.2009, 03:26 PM
Keep in mind that you will ne going from a 62t spur to a 46t spur... You will need some small pinions.
Here is the setup with the 46t kyosho spur, and a cc 2200 motor on 4s lipo...
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 11
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 4.18 : 1
Total Ratio: 13.83217 : 1
Tire Circumference (inches): 18.06 inches (458.83 mm)
Total Motor Speed: 32560 RPM
Vehicle Speed: 40.27 mph (64.68 km/h)
Effective KV Value: 2200
If you do not change the diffs you will most likely have to stick with 4s, as 5s will require tiny pinions to work. As far as 4s lipos go in the zippy line, the flightmax 5000 30c 4s pack is most likely the best bet. You really need the lsp diffs to give you some more gearing options with the kyosho spur.
Now if you stick with the stock spur, and go to 5s:
Other Ratio: 1
Spur Tooth Count: 62
Pinion Tooth Count: 12
Total Voltage: 18.5
Motor KV: 2200
Motor coil Ω: 0
Spur/Pinion Ratio: 5.17 : 1
Total Ratio: 17.08974 : 1
Total Motor Speed: 40700 RPM
Vehicle Speed: 40.74 mph (65.44 km/h)
This would be a better setup. I would still suggest the flightmax 5000 30c 5s pack for this. It will weigh more, but you wil get longer runtimes, and the equipment should stay cooler with the lower gearing. Plus you can go up a bit on the gearing, 13 or 14t spur and pick up speed without over drawing the batt.
