02.15.2009, 08:50 PM
If the feigao is a smooth can you can remove the rear endbell by just taping the shaft on a block of wood and it will pop the rear endbell off.
I run a 14xl on 8s lipo and it has great temps, 160 max after a 45min run. I think the cheaper motors just cannot handle the current a low wind can pull, they just seem less effecient that a high wind on more voltage.
