sikeston34m
sikeston34m's Avatar
02.15.2009, 11:51 PM
Sounds good, I have an angle on some neu motors, just way too low kv for car use. I guess we will see how your winding goes. I should be able to get the core out, I have mad skilz with disassembly...
Well be sure to pass along any tips that you come up with.
Some of the Epoxy they use will only let go if heated up to around 500 degrees. I'm hoping this isn't the case with the Pletty. Maybe some sort of solvent.
Every glue has a solvent that will make it let go, but finding the correct one is the challenge.
What kv are you talking on the Neu motors?
