Thread: Need a motor
Not much to see
ilpufxit
ilpufxit's Avatar
Not much to see - 02.15.2009, 11:55 PM
That's what I like about this forum, saved me time again. I opened it up and there's surprisingly little to see. Looks like the coating on the windings heated up and then sort of powdered. No burns, contact marks or visible melting though.
If the feigao is a smooth can you can remove the rear endbell by just taping the shaft on a block of wood and it will pop the rear endbell off.
I run a 14xl on 8s lipo and it has great temps, 160 max after a 45min run. I think the cheaper motors just cannot handle the current a low wind can pull, they just seem less effecient that a high wind on more voltage.
