tom255
tom255's Avatar
02.16.2009, 04:57 AM
custom work not issue for me. EC5 connectors are 5mm in diam and similar to 4mm? Issue with 5.5mm bullets and 6mm bullets that they are not last long they tend get sloppy with time. 4mm banana stile connectors are OK but dunno how they hold up 120A of current. To use deans its still the option.
I dont want to remove the shell its waist of time, better slip battery from side from spec ial shell cutout from side.
Mozzy my setup is: CC2200KV combo with Polyquest and Zippy-h 4S 5Ah batteries. Car geared to ~40mph.
New eficent motor and new batteries are new expenses for me besides rules are for 4S batts and I just bought two 4S 5Ah PQ batts. And still if you plan hold weight under control you need reduce batt capacity then your gain in time not so huge, only from efficency maybe 10%
I will try to draw something maybe post
Truggy weight is right now 4460g and I want to shave 100-200 grams more
