02.16.2009, 02:34 PM
Slightly off topic, but I have a question about the medusa front cover that you (Mike) makes.
I have the neu cover and it attaches to the motor via 4 screws. Does the medusa cover do the same? I only ask because the medusa motors have a 25mm patern and a 19mm. I have a motor with one of the 25mm patern holes stripped, and the cover would be nice cause I cold bolt it on with the other 3 good holes... Guess I need to make an order from you Mike...
