Thread: Got an Emaxx
02.16.2009, 02:42 PM
I really think that if you plan to put lst diffs in anything, might as well be a lst... Makes the emaxx look like a toy.
Lst diffs are about the cheapest method to get decent diffs. You will need some sort of adapter or cup for the 8mm pinion, like Mikes adapter for revo center drives to 8mm. Or if you use center cvds, there are a variety of dogbone cups with 8mm holes in them. I used cut down revo stub shafts as diff outputs to attach 3.3 sliders to.
