sikeston34m
sikeston34m's Avatar
02.16.2009, 07:39 PM
Thanks James. I am all about doing this on the cheap... I can be quite inventive if necessary. I am wondering if I can run 2 motors together to double up on the power? I was planning to run 12 12v batteries in series for 144v... But I could do a 2p setup with half the voltage... Depends what is cheaper. I am sure the hv setup is better, especially considering the controller options.
Hey Linc,
Ok, I have some updated information on the controllers I mentioned.
They are Curtis 24 - 36 volt brushed controllers and they are 350amp versions.
Both are Model 1187. Each one should be good for 12,600 watts of power.
