Originally Posted by What's_nitro?
I'd get rid of the 2-speed and the clutch since BL has plenty of torque. Use the motor brakes to save weight. I would run 6s on a MMM and use the punch control setting to avoid tire spin. From what I've seen those dragsters do, a setup that gives you a 60-70mph top speed would be fine.
6S?
I was thinking a little less...that would be a huge brick...I could possibly do 3-2S along the chassis.
I was thinking 4S low Mah...being that it is a dragster.
I was actually thinking of using a combo of both brakes to control a stop...
