hoober
02.17.2009, 01:46 PM
discharge any battery at any rate up to the max of the specific battery. Users choice.
Most of the time the discharge device will be maxxed out long before the battery is. It might be safe to use the continuos current rating divided by 2 if the pack is healthy. At times it may be ok to use the rating itself if the pack is accurately rated. If it's a used/bad/worn pack then the continuos rating divided by 5 may even be the max.
