Originally Posted by bent70
I have an extra mm sitting around with cc bec connected to it. I just ordered the motor the other day so its on its way. The tranny is using its 2 speed. It was the batteries I was undecided on.
I initially wanted to just run single 3s batteries in this setup as I really am not looking for back flipping power. The possibility of running the 3s in parallel will be there only if I really need the extra amperage, which is what I am unsure of.
In the previous post I meant running a single 3s or 4s battery; or running a pair of 2s batteries in series.
I would just run something like a 3S2P 8000mah pack. Your setup is pretty similar to what I was planning on running. MM, 2 speed, mech. brakes, and a 7XL instead of the Medusa. If I remember right I ran it once or twice and it was quite powerful. I used a TrueRC 3S2P 8000mah pack and no BEC and it was pretty quick. Its sat quite a while and I'm about to get some more stuff to finish it up so I'll know more soon. I might go 4S though. Still not sure, much like you, but I have 2 3S packs so what the hell...
