Electrical tape. -
02.18.2009, 06:11 AM
Electrical tape is fine for basic low voltage connections, but not where heat is a normal factor. The heat causes the adhesive to turn gooie and the tape will seperate. This is the exact reason that heatshrink was developed and is normally used where constant heat is an issue. Aside from heatshrink and/or platidip there really isn't any easy solution that I have seen. There are several ways you can cut and install heatshrink and it holds up well to heat in this application. Trial and error is what works.
