02.18.2009, 06:16 AM
pretty much but generally to an ubec rather than directly to the battery.
When i did this mod on my clod I removed the signal wire from the servo plug and instered it into a spare male plug - each servo then has two plugs, one with + and - and one with signal.
The signal plugs go to the rx.
For the + and - leads i created a 3 to 1 y adapter - plugging in the two servos and the ubec - the two servos are then powered directly from the ubec.
For the output of the y i left only the - which plugged into the rx to provide a common ground.
hope that makes sense.
