Originally Posted by BL-revo
thanks for the replies
i always thought that the higher the voltage the better because it keeps the electrics cooler?
if i was to run 6s what sort KV motor should i use? will the 1700kv motor not be slightly over the 35K RPM figure?
how many runs have you had out of your zippy lipos? because my trakpowers packed up after about 60
running higher voltage will keep the electronics cooler as long as you also run a lower kv motor or lower gearing
