12.04.2005, 04:58 AM
It is better, it has got segmented magnets and that's why it is better on a partitial load. it will get less hot, because of that AND because it should have got a higher efficiency. But like i said earlier. the 9XL IS the best bang for the buck.... you hardly will notice any difference, IF you notice any difference. the 9XL will be stronger than a 1940. it takes a 1950 to be equal in torque/power, and the 1950 takes 4mm bore pinions instead of 5mm.
