Originally Posted by jayjay283
then use the larger sanding drum sander to square it all up.
+1
I rough it out as close as I can, and then use the large sanding drum. The radius gives you nice even corners, and it looks great. I've used it to fix other people's bodies that were a little rough. Probably want to do this outside though, as it is pretty messy.
