Thread: Got an Emaxx
mkrusedc
NeuMaxx
mkrusedc's Avatar
02.18.2009, 06:16 PM
What causes the diffs to fail, are the gears themselves weak or is it something else?
what about a rear spool?
The cup is plastic as is the case. This allows for flex and then the gears strip. The ring gear screws are too small. At a minimum get an aluminum diff cup, the modified ring gear with 3 mm screws and an aluminum diff case. This at least theorecticly corrects the flaws of the 3906 diff.
...or you could spool it.
