02.18.2009, 09:14 PM
What did you use to measure the motor temps? I also have a CC 2650 geared 12/46 and 14/46 and i get temps in the 150-160 range on the endbell using the Duratrax infrared temp probe. With the eagle tree temp sensor, the temps are consistantly 30 degrees cooler and this is using thermal paste and tape to cover and attach the sensor to the motor. All runs so far have been done outside on a road.
