Finnster
KillaHurtz
Finnster's Avatar
02.18.2009, 10:24 PM
Thanks!
For some reason, I was downstairs thinking about how I was gonna make LST2 shocks fit my XT8 and the solution to this request hit me. I wasn't even thinking of anything close to this, but all of a sudden I remembered this request and an easy way to implement it. Weird.
Anyway, I added "speed vs pinion" feature to the top speed estimator page. After calculating the top speed, a gear icon will appear next to the estimated speed field. Clicking that will open a help window showing the speeds for different pinions.
Hey Brian,
Any chance you could update the Flux tranny ratios in the calc? Here is JThiessen's scan of the manual w/ the new gears
Great idea on the on the spd vs pinion. Its really nice to just look at the ranges instead of having to re-select the pinion. One thing tho, perhaps could the list read down the column instead of L->R? Just makes it a bit tougher to read. No biggie.
Also, couple other little things. The Sav XL spur, 52T iirc, Flux is 44. Lastly, regarding the Cen diffs. The genesis/nemesis and matrix all use the same diff. People may or may not know that. Don't need to update the name, but eh, some of the others are multiply named.
good job as always!
