sikeston34m
sikeston34m's Avatar
02.20.2009, 06:56 PM
Thank you guys! I'll definately check into the different choices.
I do have several motors to rebuild.
If anyone is interested in a AXI 4120 or AXI 4130 in just about any wind. I will have these rolling off really soon. Just pm me with your needs.
Has anyone ever seen a Pletty Maxx Rotor with the kevlar removed?
The Pletty Max is a 4 pole motor using 12 magnets that are 5mm wide, 30mm long and each is about 1.5mm thick. Pole configuration is NNN-SSS-NNN-SSS, making it a 4 pole motor. I'm thinking about replacing these magnets with some N50 magnets. Then replacing the Kevlar Wrap.
