Thread: My E-jato
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
02.21.2009, 11:49 AM
Originally Posted by Gee View Post
Nice setup. What did you do to get the slash rims to work on the fronts. They are a nice tire for a setup that's closer to the ground. I run them on my LS10 and they work great. Got a set from the slayer that I was going to run on the Jato also with some 14mm hub adapters for the rear but still need to figure out the fronts. Don't really want to convert to a rustler/stampede front end due to the already $$ spent on Jato rims and 17mm adapters that would then be useless.
All I did was put a Spacer.. Then a 14mm Hex and slid them on.. Works rather good and spin free with little to no play.. I can take a picture for you..As you can see from the video the handle very well and bite very well..
  Send a message via AIM to Wild YFZ 450
