Originally Posted by sikeston34m
I have a pair of 3500mah 4S 30c - 50C packs that will fit the E Revo or the E maxx.
This makes for a 8S setup that will push 105 amps continous, 175 amps Burst.
I've been running them parallel to make 4S at 7000mah.
I would like to see this coupled with a 1100kv 80mm Medusa on 8S.
Efficiency out the wazooo.
Yes there are other options, but to compromise and settle for anything less would be a crime.
The MMM software is unbeatable.
Damn, you sound like a copy cat... I currently have a pair of fp 3700 25c 4s lipos wired in series with a lutach 10s esc and an axeox 36/38/2 (1200kv or so). Not the lightest truck (bombproof emaxx with lst diffs) and this setup works well. The aveox is more 1515 size, and an 80mm medusa would be a good upgrade. I will be prating this truck to finish some other trucks. Flm savvy will get the esc, and a 3200 30c 10s pack to go with a 1521 2y (780kv). The chassis will replace the plastic chassis on the 6x6 maxx (I have 2 torpedo chassis) with the 2826/12 axi on 4s. The suspension with the lst diffs will mate with a 3905 emaxx chassis and tranny with a plett maxx on 4s with a MMM.... Time to get all of my MTs running! By next sat the hobby room will be reconfigured and I can start working on stuff again... I have spent the last month building lipos and selling!
