TK Project
wreckse
TK Project - 02.22.2009, 08:59 AM
Thanks, I was thinking about going with the aluminum arm and plastic hub set-up. I had a couple more questions if you don't mind...
Will the original turnbuckles/cups still work or would I need to buy new ones to go w/ the Savage arm/hub conversion?
I understand the heavy duty axles, is the extended 23mm hex needed or will the 17mm hex work?
Also, I see that you changed your body mounts several times. I really like the simplicity of the final set-up. Where could I buy that type of set-up?
Thanks again for the info.
