doo540
02.22.2009, 11:17 AM
I have also done this mod, for my brushless XL (neu 1515 1y 4s) So far the only thing I have found to be a problem is this. I used the drive cup that came stock with my cen gen diffs. After getting the pinion shimmed correctly it left very little of the pinion shaft sticking out of the savage bulk heads. It was causing the set screw in the drive cup to not fully seat on the flat on the pinion shaft. This caused my setscrew to come loose. So to fix that I grounf off a small amount of the end of the drive cup so that more of the drive cup fits on the shaft. Cant test this mod yet as there is about 10 inches of snow on the ground again. Global warming I sure.
