Pinions keep getting stuck!!! Suggestions? -
12.04.2005, 11:05 PM
Well it has happened a few times lately on my bl systems. I go to take the pinion off the motor and the grub screw comes out fine. Then I go to take the pinion off and it is stuck. It happened on my 8s , GTB and HVmaxx. I use RR pinions.
What is happenning? Does this happen to others?
I tighten the grub screw on the flat side.
