02.22.2009, 06:50 PM
Originally Posted by Raze ST Truggy View Post
This is just the initial stages of this buggy. The battery tray is pop rivited (no sharp surfaces) togeather around the sides and bottom. I want to coat the whole tray with something like this :
http://www.caswellplating.com/aids/plastidip.html
It was mentioned in another thread, I think I'm going to try it out and see how it works.
I also need to make real ESC and rx mounts. The zip ties are only temporrary I needed to give this thing a rip to see how it ran.
-Brian
Something else you can use is craft foam. You can get it pretty much anywhere where crafts are sold (Wal-Mart, Michaels hobby, etc), is cheap (~$1 for a 8.5"X11" sheet), and has a sticky back that sticks well, but comes off easily if you need to replace it.
I use sheets that are 1/16" thick. Cut to shape, peel off backing, and stick where you want it.
