Short. -
02.22.2009, 07:33 PM
From your description and the fact that it happened so soon after starting it up, it sounds like you had a dead short casuing a tremendous amount of heat very quickly. Either you had a bad CAP in there, or something was wired up wrong or it was touching a ground. Something shorted out for sure to cause that much heat in an instant melting the ziptie.
