Burned 6.5mm Bullett
mriccucci
mriccucci's Avatar
Exclamation Burned 6.5mm Bullett - 02.23.2009, 10:44 PM
Ok so i have a MMM v2, i just got a 1515 1.5d from a forum member. The motor is used but not much. My setup is a 3.3 revo, mechinal brakes, 4s zippy 5000 cells, geared 16/40, Im using stock diffs, locked in 2nd and center diff.
Ok so to the controller and motor ran fine the first time out, 1.5 batts and i busted a rear nuckle. motor temps up to 115 controller at 105 and batts 105. Once i fixed that, next run went fine until motor temps got to about 150 and the controller got to 120, but i guess the white bullet in the pic below was loose, as it came out of the bullet connector and stop the truck in its tracks, and it seems to have burned and chipped a little, im not sure if i should send the controller back for repair or use it as is?
