Originally Posted by bigboi146
uh oh.... I was eying some zippy 25c packs. What battery tray are you guys using?
I use Zippies now too. 5S 4000 mah. They fit great on the chassis.
I made my own tray out of an ABS Radio shack project box. Works really well, but a bit of a work to do. I cut the tray down lengthwise and in a way the bottom section would overlap to clear a shelf for the mudguard. ABS cement bonds it all back together. Then the whole thing is mounted w/ countersunk 3mm screws into the chassis.
I'd do a write up, but since Mike makes trays, its not for here. Mikes trays are very nice, clean and easy.
