02.24.2009, 02:15 AM
I would use the smallest cc car esc as it is fully adjustable, will run a brushed motor, has a lvc and is small. You can use the internal esc to run the truck, although it may be a bit much for 2 servos. I would use a ubec, adds some size, but will help.
I would also use a stand alone glo plug ignitor, like the ram setups mentioned. I guess the esc output could be used to power the ignitor... That way you can scrap the entire ez start setup.
Or use the ez start and remove the push button switch and replace it with a rec activated switch, like the robot guys use. No lvc but you could wire a li saver between the switch and the rec. No sure which is easier but the second option would be cheaper. Some sort of external bec would be required for either setup.
While remote start is cool, brushless is cooler! I have been working on a radio actuated flip over device... That would be handy.
