fastbaja5b
fastbaja5b's Avatar
02.24.2009, 08:09 PM
...ok so is that a yes or no to Mr Zippy?
and while I am here, can I run this flux with the 20t pinion, this thread here:
http://www.ausrc.com/forum/showthread.php?t=15868
They are blaming a smoked esc on not running a 25t pinion on 6s, wheras on this forum I was under the understanding that more volts = gear down to get less amps and therefore less heat.
So what is it?
Are Polyquest 5000mah 25c 3s packs sufficient?
Say Less, Do More.
