Center diff
ilpufxit
ilpufxit's Avatar
Center diff - 02.24.2009, 09:26 PM
As far as I can see, there's no good way to use the Kyosho spur with the RCM mount. Shims don't really help because there just isn't enough room between the two bulkheads to make it work.
I did just finish installing a Kyosho spur on a Smartdiff so that definitely works (real tight fit though). I use the RCPD mount which I don't like nearly as much as the RCM one but it sure is quieter with the plastic spur.
