02.25.2009, 02:59 AM
the best option i could see is a battery and mount that are made for each other.... I see a hardcase lipo in which the protective shell itself is part of the holding mechanism. So latches are located on the chassis itself and the battery "clips" into the latches. If you wanted to you could even have the battery leads be located at the latch so that when you latch the battery it is automatically connected to the esc, no wires or other connections needed. obviously this would be a quick release system, and there is more that needs to be thought about but i think the general idea is good.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
