Originally Posted by Metallover
Just a small off topic question is there a good way to solder to lipo tabs? My soldering iron can't seem to heat it enough to get a really good soldering joint.
If it's an aluminum tab you need to use zinc flux and aluminum solder. If it's a copper tab it should solder really quick and easy with even a weak iron.
