02.26.2009, 11:32 PM
Originally Posted by fastbaja5b View Post
So if I use the Zippys but stick on the 20t pinion or even gear down, I should have less issues than if I go to 25t? (Assuming a 6s set up ZIppy Lipo 5000mah 20c-30c)
..naturally that's assuming the motor isn't telling me it's undergeared (which is why the DX3s temp sensor is right on the can)
That is how it works. Taller gearing equals more current draw. No way to get around that. An 18t pinion sounds like a good setup to me...
