PBO
RC-Unobtainium
PBO's Avatar
02.27.2009, 04:16 PM
Originally Posted by SunnyHouTX View Post
PBO: good luck on your quest for 100mph. I was on track for 100mph last year and had to get away from it due to a distraction that came in the form of RC drag racing. Anyway, I was getting up to 90mph with a 5S Hyperion 5350LCX, Lehner Basic XL3100, Mamba Max and 18/36 Mod1 gearing. I had OFNA belted tires with tread in the rear using New Era 17mm hubs and Bandit front wheels. I also had a FLM chassis in stock length as well as front extended A-arms, stock length rear A-arms, and trans case. I used a JConcepts Bandit body for aerodynamics with front and rear wings like you have. My suspension looks pretty much like yours but with 4-Tec shocks in the fronts.
Again, all the best to you on this.
Thanks Sunny
I know your configuration very well, you have been a major influence for my attempt & yes some of the design elements of mine are inspired by yours. All the best with the drag racing, it's a shame you won't be running anymore
