03.01.2009, 05:45 PM
Ha, looks like that dinosaur uses a serial plug to hook the harness up!
Can you get us a closer pic of the harness. I wonder if it uses the tap wires to charge and not the main leads. If so most lipos use small gauge wires for the taps, and they can only handle 2amps, much more and the thin wires get very hot and could melt into the cells...
