03.01.2009, 07:57 PM
I wasn't implying to jump in and do it on advice from a forum rather getting you to think about other options to regular pumping out. There are products that will seal in the wet even if it leaks from the other side. Speedliner probably isn't sound advice, it was just the first to spring to mind.
I'm sure Brian has his head screwed on and the outcome will be better than the current situation. On the other hand if the basement is constantly below the water line and has'nt been engineered to suit it might be opening a can of worms.
