Originally Posted by lincpimp
Sounds like the bec died... You can try recalibrating it, and check to make sure that you have not altered the throttle channel expo, epa or any other settings to do with the throttle channel. Zero everything just to make sure and recalibrate it...
I reset the MMM to factory (Castle, not HPI) defaults, and voila! it works again. Now I just need to figure out which setting I gave it that it didnt like. I know I changed the motor timing to one of the lowest settings, and I changed the brake power to somewhere around 70%. I likely revised the punch control also, but I doubt if I gave it much.
Originally Posted by fastbaja5b
Is your LVC still set to 3s Lipo packs?
LVC was on Auto Lipo, and is again.
