Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.02.2009, 12:46 AM
Looking great so far
What color scheme are you going to run on the body, or do the 2.0 come prepainted?
Just curious as to what part you had to "dremel action it took to grind down the center diff mount", was it the RCM mount or the top brace mount. With my 1.0, I had to dremel the top mount and bottom plate only using the Losi conversion for fitting the plastic spur. I am looking at the RCM mount as a lighter option, since you have one, can you use M4 screws through the mount instead of M3 or will they have to be opened wider?
Again, looking real factory like
I like it.......I LIKE IT ALOT!!!!!!
