03.02.2009, 01:14 AM
Update:
- Added Proline Switch (Slash) tires to the Proline 2.2" rim section for the tires.
- Changed Baja spur gear pitch is Mod 1.5. Thanks to RCM forum member doo540 for this info.
- Alphabeticalized tire list.
- Added a BL Parameter Comparison page which graphically displays the effect that gearing, motor kv, and voltage play in speed, temps, and current draw. In BETA right now for user input.
- Removed Savage transmission ratios until I get the proper gear tooth counts.
Play around with the new page ("BL Parameter Comparison" under the "Other Stuff" section). If it seems confusing or isn't right, I'll just remove it.
