03.02.2009, 09:28 PM
I am in the process of converting a 3.3 as well. What has been said to me many times is that the stock diffs will not hold up long to 5s power, which is what I will be running. Hence, Mike sells hybrid cases which work w/1/8 gears. They are not cheap, but, on 5s I would seriously consider them. If not the hybrid cases, at least AL inner and outer cases w/hardened gears which will reduce flex a lot.
Welcome to the madness!
