03.02.2009, 11:55 PM
Originally Posted by drkros3 View Post
im looking for something with more mah for more run time. 4500mah would be less then what i already have.
im switch to the tekno kit so it should be more ballanced cause the esc and motor and brake servo are on one side and on the other side would be the battery and the stearing servo. so should be pretty ballanced.
I got ya... I will add that the true rc pack will most likely be too big to fit under the body... Kinda like a maxamps 8000 4s pack. It is huge.
Any reason that a battery swap will not work for you?
