PBO
RC-Unobtainium
PBO's Avatar
03.03.2009, 02:20 AM
Originally Posted by bustitup View Post
yes its for a boat
anyone got any ideas on how to build a water cooler system for a neu castle 2200kv motor
I'm thinking of just making a coil around motor with aluminum tubing...would copper be better?...easier to bend
be pretty nice if you could devise some way of making a slightly bigger can to fit around the fins and sealing the ends with o-rings and sealant like on the smooth can coolers where the water actually flows over the motor
Try this from www.fastelectrics.com
edit: I posted without reading your last paragraph & I now assume you have a finned can? They do a larger one that may fit over fins although I doubt it would be effective even if it did
