skellyo
skellyo's Avatar
03.04.2009, 10:01 AM
I too have run mine with the 6S/20T, and I liked how it ran - but it was a bit on the uncontrollable side. I'd like to take some of the pep out of it - and the 25T may just do that (as opposed to 4S, which just seemed too tame for me). However, that is going to make it a PIA to run both 4S and 6S in one outing. So I need to rethink and make a commitment to one pack set up - which kinda sucks IMHO.
If you want to take the pep out of it, either gear way down or drop your voltage down from 6S. Putting the 25T pinion on it is like trying to slow down a drag racer by putting monster truck tires on it...it's just not an intelligent solution to the problem. All you'll do is increase the current draw and start potentially causing heat issues.
The whole point behind what the guys from Castle are saying is to use common sense when gearing these trucks regardless of what the manual says. This post backs that up:
http://www.rc-monster.com/forum/show...&postcount=111
